1. Log in as an administrator
2. in my computer, choose folder options, click on the view tab, scroll right to the bottom of the 'advanced settings' section and ensure 'user simple file sharing (recommended)' is deselected. OK it.
3. right click on the drive that you want to take ownership of (in my computer) and choose properties
4. click on the 'security' tab
5. click the 'advanced' button
6. click the 'Owner' tab
7. under 'change owner to:' select your username
8. check the 'replace owner on subcontainers and objects'
9. click Apply (may take some time)
10. click on the 'Permissions' tab
11. click the 'add' button
12. type 'everyone' for all users to be able to access the drive. Type your user name just for yourself. OK it.
13. click the 'full control' checkbox under 'allow.' OK it.
14. check the 'replace permission entries on all child objects...' checkbox
15. OK it (result may take some time)
16. OK the last window
17. Enjoy
