Windows® XP File Association Fixes
List info and Thanks to
www.dougknox.com
Batch File Association Fix (Restore the default associations for BAT files) http://www.dougknox.com/xp/fileassoc/ba ... _assoc.zip
CAB File Association Fix (Restore the default associations for CAB files) http://www.dougknox.com/xp/fileassoc/xp_cabfile.zip
CHM File Association Fix (Restore the default associations for CHM files) http://www.dougknox.com/xp/fileassoc/xp_chm_fix.zip
COM File Association Fix (Restore the default associations for COM files) http://www.dougknox.com/xp/fileassoc/xp_com_fix.zip
CPL File Association Fix (Restore the default associations for CPL files) http://www.dougknox.com/xp/fileassoc/xp ... _assoc.zip
Directory Extension Fix (Restores defaults to HKCR\Directory) http://www.dougknox.com/xp/fileassoc/xp ... ry_reg.zip
Drive Association Fix (Restores default settings for hard drives) http://www.dougknox.com/xp/fileassoc/xp ... on_fix.zip
EML File Association Fix (Restores defaults for EML files) http://www.dougknox.com/xp/fileassoc/xp ... _assoc.zip
EXE File Association Fix (Restore default association for EXE files) http://www.dougknox.com/xp/fileassoc/xp_exe_fix.zip
Folder Association Fix (Restore default associations for File Folders) http://www.dougknox.com/xp/fileassoc/folder_reg.zip
GIF File Association Fix (Restore default associations for GIF Files) http://www.dougknox.com/xp/fileassoc/xp_giffile_fix.zip
HLP File Association Fix (Restore default associations for HLP files) http://www.dougknox.com/xp/fileassoc/xp ... le_fix.zip
HTA File Association Fix (Restore default associations for HTA Files) http://www.dougknox.com/xp/fileassoc/xp_hta_fix.zip
HTM/HTML Associations (Restore the default associations for htm/html files) http://www.dougknox.com/xp/fileassoc/ht ... on_fix.zip
ICO File Association Fix (Restore the default association for ico files) http://www.dougknox.com/xp/fileassoc/xp ... oc_fix.zip
INF File Association Fix (Restore the default assocation for INF files) http://www.dougknox.com/xp/fileassoc/xp_inf_assoc.zip
Internet Explorer Desktop Icon Fix (Restore the default behavior for the Desktop IE icon) http://www.dougknox.com/xp/fileassoc/ie ... p_icon.zip
JPE/JPG/JPEG Association Fix (Restore the default associations for jpe/jpg/jpeg files) http://www.dougknox.com/xp/fileassoc/xp ... oc_fix.zip
LNK (Shortcut) File Association Fix (Restores Default Shortcut Behavior) http://www.dougknox.com/xp/fileassoc/linkfile_fix.zip
MPG/MPEG File Association Fix (Restores default associations for MPG/MPEG files) http://www.dougknox.com/xp/fileassoc/xp_mpg_fix_reg.zip
MSC File Association Fix (Restore default associations for MSC files) http://www.dougknox.com/xp/fileassoc/xp_mscfix.zip
MSI File Association Fix (Restore default associations for MSI files) http://www.dougknox.com/xp/fileassoc/msi_assoc.zip
MSP File Association Fix (Restore default associations for MSP files) http://www.dougknox.com/xp/fileassoc/xp_mspfix.zip
REG File Association Fix (Restore default associations for REG files) http://www.dougknox.com/xp/fileassoc/xp_regfile.zip
SCF File Association Fix (Restore default associations for SCF files) http://www.dougknox.com/xp/fileassoc/scf_assoc_fix.zip
SCR File Association Fix (Restore default associations for SCR files) http://www.dougknox.com/xp/fileassoc/xp_scr_fix.zip
TXT File Association Fix (Restore default associations for TXT files) http://www.dougknox.com/xp/fileassoc/xp_txt_fix.zip
TIF/TIFF File Association Fix (Restores default associations for TIF/TIFF files) http://www.dougknox.com/xp/fileassoc/xp_tiff_fix.zip
URL File Association Fix (Restores default associations for URL - Internet shortcuts) http://www.dougknox.com/xp/fileassoc/xp ... ut_fix.zip
VBS File Association Fix (Restores default associations for VBS files) http://www.dougknox.com/xp/fileassoc/xp ... iation.zip
ZIP Folder Association Fix (Restores default associations for ZIP Folders - REG File) http://www.dougknox.com/xp/fileassoc/zipfolder_fix.reg
