[Delete]
- The Quinsta
- Combat Arms: thequinsta
Re: Dell Gx280
What is the status of the LED or light..??....i found this, hope it helps
http://support.dell.com/support/edocs/s ... #wp1114432
Re: Dell Gx280
Truttster wrote:I Have Two Dell GX280 SFF And Will Not Power On. Motherboard Capacitors Are Fine.
Any Suggestion Of What To Do?
What about the caps under the fan, as that row has a problem with heating.
You might have to remove the cpu fan to see them
